Pro Tools makes music creation fast and fluid, providing a complete set of tools to create, record, edit, and mix audio. Get inspired and start making music with a massive collection of plugins, instruments, and sounds. Tackle your most ambitious visions with proven features that power you through the most demanding projects.
Screenshot of Pro Tools Sketch on computer
Keep pace with any creative process
From idea to final mix, Pro Tools offers seamless end-to-end audio production that covers every stage of the creative process. Start with non-linear Sketches to play with loops, MIDI, and recordings, and then move to the timeline to refine your arrangements using world-class editing and mixing tools.
A common language across audio
Trusted by top professionals and aspiring artists alike, Pro Tools is used on almost every top music release, movie, and TV show. And because the Pro Tools session format is the industry’s universal language, you can take your project to any producer or studio around the world.
Shot of producers working with Pro Tools in studio
Collage of Sonic Drop and Inner Circle rewards
The DAW that keeps on giving
Beyond the comprehensive assortment of included plugins, instruments, and sounds, your Pro Tools subscription/license also delivers quarterly feature updates, new plugins, and sound content every month with Inner Circle* rewards and Sonic Drop to keep you inspired.
CHOOSE YOUR MUSIC SOFTWARE
Pro Tools Intro
Get an introduction to music creation with a FREE version of Pro Tools
Pro Tools Artist
Get all the tools, instruments, loops, sounds, and effects you need to start making music
Pro Tools Studio
Get the industry-standard toolset and more plugins for professional music production
Pro Tools Ultimate
Get the complete advanced toolset and workflows for music and audio post
Try the full-featured version of Pro Tools—free for 30 days
Download now
SKETCH + CREATE
Get inspired
Bearded man wearing durag playing bass guitar
Spark ideas with a massive music software collection of plugins, loops, and samples—plus, get a Sonic Drop of fresh new content each month. No matter what type of music you create, you’ll find tons of incredible sounds to explore and tweak.
Make music with MIDI
Pro Tools interface showing multiple tracks with focus on piano control
Build up songs quickly and create more realistic-sounding tracks with easy-to-use MIDI tools—including new MIDI effect plugin support. Add loops that auto-conform to your session tempo. And freely create and experiment without stopping playback.
Invite ideas to happen
Shot of two musicians using Pro Tools Sketch to write song
Trigger samples and loops, record audio, and capture MIDI performances with the new Sketch window and iPad app to quickly work up ideas. Drag-and-drop clips and experiment with arrangements to create something you love.
Play virtually any instrument
Pro Tools interface with mutiple tracks showing 16 pads and knob controls
Have thousands of instrument sounds at your fingertips with GrooveCell, SynthCell, PlayCell, Boom, Mini Grand, Xpand, and more included. Even connect your favorite electronic instruments and music apps through Ableton Link.
PERFORM + RECORD
Record high-quality audio
Pro Tools timeline highlighting tracks set to strings and vocals
Seamless punch and loop recording. Automated playlist tracking. All in pristine 32-bit floating/192 kHz audio resolution. With Pro Tools, you can capture performances that sound like a hit record from the start.
Capture inspired performances
Man playing double-decker synthesizers
Ever have that moment where you play something amazing but didn’t hit record? With Retrospective MIDI Record, you can bring in those MIDI improvisations retroactively in your DAW to recoup that spontaneity.
Get seamless hardware integration
Music production hardware vertical rack setup with Pro Tools Carbon at top
Use any audio interface that meets your needs to record into Pro Tools. Or add an Avid audio interface or system and you can record through plugins with near-zero latency and get guaranteed performance.
Create the perfect take
Different Pro Tools tracks with highlight on lead vocal group track
Experience the easiest audio comping workflow for creating flawless performances quickly. You can even cycle through different playlist takes to hear what works best and create something truly inspired.
EDIT AUDIO + MIDI
Edit your way
Photo from behind showing Pro Tools user working with the software
When it comes to manipulating tracks in Pro Tools, there’s no right or wrong way. Shape, fix, chop, cut, and tweak audio and MIDI the way you want in a creative DAW that gives you limitless flexibility and freedom to play.
Tweak audio timing and pitch
Pro Tools timeline with small window showing Elastic Properties settings
Easily fix timing, beat match audio, and correct notes with Elastic Audio. Or with Melodyne now integrated directly into Pro Tools via ARA 2, you can quickly manipulate pitch and time in real time—without roundtripping audio.
Fine-tune MIDI performances
Pro Tools track showing piano timeline with editor notes on velocity
Quantize notes. Adjust note durations. Transpose recordings. Add dynamics by varying note velocities. Rearrange parts with Folder Tracks. And add more humanistic soul using MIDI Real-Time Properties and effect plugins.
Turn audio to MIDI and vice-versa
Pro Tools hover window showing Audio to MIDI Properties settings
Drag an audio sample to a MIDI track or convert an audio track to MIDI, and you can change the instrument, switch out samples, and edit notes. Or drag a MIDI clip to an audio track for more creative editing possibilities.
MIX + MASTER
Shape mixes with powerful plugins
Batch of Pro Tools plugins open simultaneously
Get the classic sounds of legendary analog gear—from compressors and EQs to unique effects—with over 120 plugins to fine-tune tracks. Plus, get a monthly Sonic Drop of new content and $3,000+ of additional plugins, sounds, and more with the Inner Circle.
Mix Dolby Atmos® music
Screenshot of internal Pro Tools Dolby Atmos Renderer
Give your fans a whole new way to experience your music. Get the capabilities to mix surround and immersive sound—including the new integrated Dolby Atmos Renderer—with Pro Tools Studio and Ultimate. See what you can do >
Get unmatched mixing automation
Pro Tools in-software window for automating volume shifts and other modifications
Pro Tools offers the most advanced and accurate automation of any DAW. Automate anything—from track volumes and panning to plugin settings and sends—to achieve your best mixes possible.
Take hands-on control of your mix
Music editor working with Pro Tools using Avid Control hardware
Only Avid control surfaces—from the free Avid Control app to the modular S6—provide the unparalleled DAW integration needed to access tracks, plugins, sends, and more from the surface, speeding up editing and mixing.
Woman with Audio-Technica headphones singing in a music studio
DISTRIBUTE YOUR MUSIC
Be heard around the world
Stream your music on Apple Music, Spotify, TIDAL, Deezer, TikTok, Amazon Music, and many other top streaming outlets. AvidPlay supports the highest quality audio (24-bit/192 kHz), including Dolby Atmos music, making music distribution easy and affordable. Grow your fanbase and keep 100% of your rights and earnings. Plus, distribution of your first music single is free, on us! See how >
