Record, edit, mix, and deliver sound for film, TV, video games, and more with the proven audio production tools professionals have long relied on to do their best work. From ADR and Foley to sound design and Dolby® Atmos workflows, Pro Tools provides the power and precision you need to create and deliver exceptional work with confidence and ease.
WHAT'S NEW
See what's new in Pro Tools 2022.12
Get macOS Ventura support, a new scripting SDK that enables developers and facilities to create apps that integrate with Pro Tools, and numerous bug fixes and performance improvements, as well as a public beta that offers native Apple Silicon support.
And in case you missed it, check out Pro Tools 2022.9
Alter pitch and time in real time using Melodyne directly in Pro Tools with new ARA 2 integration. In addition, you can send audio to and from Pro Tools and other apps using Aux I/O. And if you're new to making music (or DAWs in general), check out Pro Tools Intro—a free new version of Pro Tools.
WHAT'S NEW
RECORD ADR + FOLEY WITH POWERFUL AUDIO SOFTWARE
Replace or add dialogue
Create flawless ADR and voiceover performances by loop recording your talent in sync with the picture, then comping together the best takes. For ultimate sound quality and sync, add an Avid audio interface or system.
Capture Foley performances
Use blank clips to cue a Foley session quickly and record high-quality sound effects—such as footsteps, rain, punches, and dish rattling—in sync with the movement onscreen to re-produce the sounds of everyday life.
DESIGN, CUT, AND SYNC SOUND TO PICTURE
Create realistic atmospheres
Design and build up rich sonic elements and ambience that bring life to moving pictures. With up to 2,046 voices/audio tracks and 64 video tracks at your disposal, you can create immersive, unforgettable soundscapes.
Edit and position sound
Work with HD, 4K, and other high-res media directly, enabling you to place and edit sound to picture with great precision and accuracy. From trimming clips and leveraging Clip Effects to positioning elements in 3D audio.
Design unique sounds and effects
Create and manipulate sounds for every visual element in a scene—from revving engines to an alien invasion—with over 120 plugins, a huge sound library, Melodyne essential, and Elastic Audio to help you sculpt your sonic vision.
Streamline the editorial workflow
With clip gain, track automation, markers, and track effects compatibility between Pro Tools and Media Composer, you can pick up where the video editor left off to conform sequences. Or sync a session directly with a sequence.
MIX, MONITOR, AND DELIVER SOUNDTRACKS
Mix the largest sessions with ease
Get the most advanced automation in the industry to turn around complex productions faster. Handle hundreds of thousands of clips with Folder Tracks. Control multiple Pro Tools rigs at once. And save tons of time with macros.
Immerse yourself in sound
Experience the easiest and most efficient Dolby Atmos and Ambisonics workflows with tightly integrated mixing and monitoring solutions. Plus, get advanced workflows for surround and immersive mixing.
Take control of every element
Dramatically boost your mixing efficiency and precision with an Avid control surface, which provides unparalleled DAW integration, plus joystick and PEC/Direct options for S4 and S6 to speed up mixing and re-recording tasks.
Deliver with confidence
Pro Tools provides all the technology and workflows you need to meet the technical and delivery specifications required for theatrical release, broadcast, Netflix, streaming, gaming, and other video productions.
