Screenshot of Pro Tools with MIDI Quantize Toolbar Menu
The Pro Tools 2022.9 software release delivers a number of major new features and enhancements and is available to all current Pro Tools customers on an active subscription or perpetual Software Updates + Support Plan. This release also introduces Pro Tools Intro—a new free version of Pro Tools.
What’s New in Pro Tools 2022.9:
  • Pro Tools Intro is a new, free version of Pro Tools that is ideal for those new to producing music with a DAW, providing all the essential audio and MIDI tools needed to create music and includes 36 core effects and instrument plugins. Pro Tools Intro also becomes the default rollback for any subscription customer who does not renew their license—read the Pro Tools Intro blog for all the details
  • ARA 2 Melodyne support integrates this world-class pitch and time toolset into the Pro Tools Edit window—check out the ARA Melodyne blog to learn more
  • Aux I/O enables you to stream audio between Pro Tools software and other audio applications (such as Zoom, Apple Music, Dolby Atmos® Production Suite, etc.), as well as additional audio hardware beyond your primary Playback Engine (macOS only)
  • SoundFlow Cloud Avid Edition is now also included with all Pro Tools Studio annual subscriptions, as well as with all Pro Tools Studio perpetual licenses with an active support plan (SoundFlow was previously only included with Pro Tools Flex annual subscriptions and Pro Tools Ultimate perpetual licenses with an active support plan)
  • Other features and enhancements:
    • Timecode Overlay X/Y settings for fine-tuning the Timecode Overlay position in the Video window
    • Increased marker count from 999 to 32,000
    • Quantize Toolbar controls in Edit and MIDI Editor windows
    • And more
Let’s take a closer look at some of these—be sure to also check out the What’s New in Pro Tools 2022.9 doc for a deeper dive on how to use these new features.
AUX I/O
Aux I/O is a Pro Tools macOS feature that allows you to add any Core Audio devices as extra inputs and outputs to your current Playback Engine. These will show up as additional devices in I/O Setup, just like any other interface. This feature has varying channel counts for Pro Tools Ultimate, Studio, and Artist.
Screenshot of Pro Tools Aux IO Window
This idea was conceived near the start of the pandemic. We were hearing endless tales of people wanting to incorporate things like Zoom, NoMachine, and Evercast into Pro Tools; the need was everywhere. During development, we realized that there was a bigger feature here, which could solve a lot of other problems, such as piping audio between applications or other hardware interfaces on the same machine. Use it to preview audio from your sound library, access audio from AU plugins with Apple MainStage, or pull in a binaural re-render from the Dolby Atmos® Production Suite and send it to a headphone feed. You can even route your system audio into Pro Tools with ease.
It is important to understand what Aux I/O is, and what it isn’t. Aux I/O is a utility that allows you to send and receive audio to and from your session. However, it will not have the same performance characteristics as your main Playback Engine: latency will be higher and may not be consistent between playback passes. For example, if you need to punch into an existing track with sample accuracy, it is best to use your main Playback Engine. You could use Aux I/O to send and receive from the Dolby Atmos Production Suite, but keep in mind that the latency will be higher than simply using Dolby Audio Bridge as your main Playback Engine.
Aux I/O also has its own “Ignore Errors During Playback” checkbox, so the main Playback Engine can keep track of mission-critical audio, while Aux I/O can be more tolerant and allow momentary dropouts.
There are two main classes of devices to be aware of: interfaces and virtual devices. Interfaces have both inputs and outputs. Virtual devices are simply an audio pipe. They can be used as either inputs or outputs. Think of them as an audio bus for your OS. Pro Tools installs its own virtual devices that show up as 64, 32, 16, 6, and two 2-channel Core Audio devices. The Pro Tools Reference Guide provides instructions on how to change the device count and channel count for each device, if needed.
One of the challenges when developing Aux I/O was keeping devices in sync with the main Playback Engine. When using interfaces, it is important to apply a common clock between your main Playback Engine and Aux I/O device. If this is not possible, be aware that the clocks will drift, and there may be audio artifacts over time. Virtual devices cannot be clocked externally, so we have built an internal mechanism to clock the Pro Tools Audio Bridge. This means Pro Tools Audio Bridge will stay in sync with any hardware your main Playback Engine is set to. The Dolby Audio Bridge can also leverage this internal clocking mechanism. Other virtual devices do not have this mechanism and will likely encounter artifacts over time, so we recommend you use the Pro Tools Audio Bridge whenever possible.
Experiment and find creative uses for this feature. The possibilities are endless!
Check out some videos about how to use Aux I/O with various workflows:
Aux I/O - Introduction and Setup
Aux I/O with Ableton Live
Aux I/O with Zoom
Aux I/O with Apple MainStage
Aux I/O with Dolby Audio Bridge
Aux I/O with Sound Effects and Libraries
TIMECODE OVERLAY X/Y SLIDERS
Pro Tools 2022.6 brought the ability to overlay timecode over video. It used six presets to quickly place the overlay in key positions around the border of the picture. We quickly realized that 6 sizes don’t fit all, so in 2022.9 we’ve added the ability to fine tune the overlay with X/Y sliders. This way, if you need to account for some masking from your display, or if the overlay just doesn’t quite sit where you want it, you have the option to nudge it into the correct place.
Screenshot of Pro Tools Timecode Overlay XY controls
One thing to keep in mind is that setting the sliders each to 0 does not mean that the text will be directly in the center of the screen. The slider coordinates are based off of the presets. For example, if you choose “Top Left”, and then set the X/Y sliders to 0, 0, the top left corner of the text would be in the center of the screen. We do this because it is much easier to calculate the preset locations with all of the various aspect ratio and text font size combinations. This means you can use a preset to quickly set the overlay to the roughly desired position, then use the X and Y sliders to the exact position that works best for you.
32,000 MARKERS
Why 32,000? Why not? We know that for some people, 999 just isn’t quite enough. 32,000 happened to be the closest to infinite that we could get without having to do extra coding. Hopefully a little work in the marker area can serve as foreshadowing for things to come.
Screenshot of Pro Tools markers
QUANTIZE CONTROLS IN THE EDIT WINDOW AND MIDI EDITOR TOOLBARS
Building upon the quantization feature improvements in 2022.6, Pro Tools 2022.9 adds Quantize Controls in the Edit Window and MIDI Editors for much improved access to this crucial music creation functionality.
Screenshot of Pro Tools Edit Window with MIDI Editor
In previous Pro Tools versions, all of the quantize functions lived in the Event Operations window. Although version 2022.6 added a default shortcut (Command + Option + 0 on Mac and Ctrl + Alt + 0 on Windows) to trigger the quantize operation, the Event Operations window still had to be opened to see and adjust settings. The new Quantize Controls place the most important quantize settings right in the toolbar of the Edit Window and MIDI Editors (both docked and window) so they are always visible and available (you can, of course, hide it if you’d like), and should help you capture and edit MIDI performances with more speed and ease.
In the new toolbar cluster you can see and set the quantize grid value along with two primary parameters. The “Q” button executes quantize, and the gear/cog button opens the Event Operations Quantize page for quick access to more parameters. The gear/cog button also shows you whether any of these additional parameters are enabled or not. Note that Pro Tools has a single set of quantize settings which are displayed and adjusted from the toolbar Quantize Controls and Event Operations Quantize page. Because of this, parameter changes in any one of these locations will be immediately mirrored everywhere else.
Screenshot of Quantize controls in Edit Window toolbar
Screenshot of Quantize controls in MIDI Editor toolbar
Because the Quantize Controls simply mirror the Event Operations Quantize page, operation and options are identical.
The Grid value can be a note value such as 1/8 or 1/16 notes, or a groove, or be set to “Follow Bars|Beats Grid” (option added in 2022.6).
Screenshot of Pro Tools Quantize Grid menu
The last option uses the current timeline grid as the quantize grid, and can be very intuitive since the timeline grid effectively functions as visual guidelines for where the notes will be quantized to. You can further streamline the workflow by using shortcuts Shift + -/+ to decrement or increment the timeline grid value—check out the Pro Tools 2022.6 blog to learn more.
Screenshot of Pro Tools follow bars beats grid example
Two main parameters are available to tailor your quantize operation. With a note grid or “Follow Bars|Beats Grid”, you can adjust Strength and Swing. With a groove, you can adjust Timing and Velocity.
Screenshot of Pro Tools Notes Grid shows strength and swing
Screenshot of Pro Tools Groove Grid shows timing and velocity
The gear/cog button opens (and closes) the Event Operations window for even more parameters. Of course, you may continue to use Option + 0 (Alt + 0 on Windows) if you’d like. This button lights up blue if any of these additional parameters are enabled.
Screenshot of Pro Tools Gear cog button opens Event Operations window
When you are ready to quantize, select some MIDI notes and click on the “Q” button or use Command + Option + 0 (Ctrl + Alt + 0 on Windows). Remember that Elastic Audio events can also be quantized.
The Quantize Controls are displayed by default, but you can always show or hide it using the toolbar menu in each location.
Screenshot of Pro Tools Quantize controls in the Toolbar menu
The Quantize Controls in the toolbars may seem like a small addition, but by streamlining a common step in capturing and editing MIDI performances, we hope the cumulative positive effect will be far greater than its diminutive appearance.
SOUNDFLOW CLOUD AVID EDITION NOW INCLUDED WITH PRO TOOLS STUDIO
Previously only included with Pro Tools Flex annual subscriptions and current Pro Tools Ultimate perpetual licenses, SoundFlow Cloud Avid Edition is now also included with all Pro Tools Studio annual subscriptions, as well as with all Pro Tools Studio perpetual licenses with an active support plan. SoundFlow Cloud Avid Edition is a workflow automation platform that enables you to perform complicated, click-heavy tasks in a single keystroke, button press, or shortcut. With SoundFlow Cloud Avid Edition, you have access to 1,600+ prebuilt macros and commands for Pro Tools that can be custom assigned and triggered by keyboard shortcuts, MIDI controllers, HID devices, and OSC-enabled controllers. Learn more about SoundFlow here.
AVAILABILITY
Pro Tools 2022.9 along with the included ARA 2 Melodyne integration and updated Melodyne installer is now available for all current Pro Tools customers on an active subscription or perpetual Software Updates + Support Plan. You can update through Avid Link or find it in your Avid Account. If you need to renew your Software Updates + Support Plan for Pro Tools or want to get current to the latest version, you can find options to do so here. And if you’re new to Pro Tools, you can try out the latest version with our free 30-day trial. For more details about this release, please see the new documentation now available in your Avid Account.
Celemony, Melodyne, DNA Direct Note Access and ARA Audio Random Access are registered trademarks of Celemony Software GmbH. Dolby Atmos is a registered trademark of Dolby Laboratories.
Whats New in Pro Tools 20226
Chris Winsor and Daisuke Naito
Chris has spent the last 14 years testing and designing solutions at Avid concentrating on audio post workflows, while Daisuke has a music production and recording studio background, and has been involved in Pro Tools development for nearly 20 years.
